mac daddy racing
I have a 1980 yamaha 440 srx that is pretty much stock other then a 108 comet primary clutch. I use this sled to oval race in a field with a few buddies every winter. What should i do to help it run better. What poundage should i set the secondary at to help with the hole shot. What gear ratio should I run? Is a 108 comet too big for the primary? Im pretty sure I have the jetting close and it wants to bog when u floor it from a dead dig. Im thinking my clutching is way off. It has stock carbs on it right now but I have a newer set of keihin 38 mm round slide carbs. Also I have heard people say not to mess with the timing, why is that? Are they already tuned hot enough from the factory?
Im new to the forum and any help would be great,
Thanks, Rick
Thanks, Rick
