Does anyone know where the test port for the power valve servo is for an 04 SXViper mountain? I'm trying to hook a 12 v battery up to the test port but it appears that the example in the tech section refers to an SRX.
I've found a white connector that had a blue and red wire running into it below the servo motor on the left side (viewed from sitting on the seat). This one did not have a dummy plug in it. It was just open ended.
I found another plug (black) on the right side above the foot well but this has a red w/ yellow stripe, a red, and a black wire running into it. Three wires vice two mentioned in the tech section.
This is not an ER. Just a pull start. I know that I could do this by idling it down while running but I was hoping I could do it this way since I made the pigtail for it.
I would appreciate any help.
this is your plug.... red wire goes to pos black to neg ..disregard the red w yellow stripe wire hook up turn your key to on and the servo will go to the power valve open position. as long as its working properly.Newbee said:I found another plug (black) on the right side above the foot well but this has a red w/ yellow stripe, a red, and a black wire running into it. Three wires vice two mentioned in the tech section.
Andrew k, I noticed that the odd ball wire is actually red with a white stripe. But that was the connector that I suspected to the one. Now I know for sure. Thanks for the help I really appreciate it!
