Power valve servo test port
OldIron
Lifetime VIP Member
NorCal
Does anyone know where the test port for the power valve servo is for an 04 SXViper mountain? I'm trying to hook a 12 v battery up to the test port but it appears that the example in the tech section refers to an SRX.
I've found a white connector that had a blue and red wire running into it below the servo motor on the left side (viewed from sitting on the seat). This one did not have a dummy plug in it. It was just open ended.
I found another plug (black) on the right side above the foot well but this has a red w/ yellow stripe, a red, and a black wire running into it. Three wires vice two mentioned in the tech section.
This is not an ER. Just a pull start. I know that I could do this by idling it down while running but I was hoping I could do it this way since I made the pigtail for it.
I would appreciate any help.
this is your plug.... red wire goes to pos black to neg ..disregard the red w yellow stripe wire hook up turn your key to on and the servo will go to the power valve open position. as long as its working properly.
Andrew k, I noticed that the odd ball wire is actually red with a white stripe. But that was the connector that I suspected to the one. Now I know for sure. Thanks for the help I really appreciate it!
