Driver lock rings
suva57
Idaho
I just got done swapping 8t drivers and a 2" track onto my wife's Venture and I noticed my Mountain Max has rings with set screws on the outside of both guide wheels, the Venture's 9 tooth drivers didn't have any. The manual shows that the SX and MM came with the lock rings and the Venture didn't. Will I be okay without them or should I tear it back apart and put some in?
More of an issue on trail sleds or high HP sleds that see hard sideways pressure on the track a lot. However, if Rich has run without them I would consider running without them well tested.
