Belt adjustment
mttraveller
Billings, Mt
I was looking at my clutch belt and it looks like it is sitting a little low. How do I adjust it and how will it afect the sled. I am clueless as to the performance of my sled. I know it is fast and a blast to ride.
there are 3 lil' bolts in the back of the sec. add / remove the washers to adj. Your bolts ,though are probably wore down and need to be replaced!
Maybe you should leave well enough alone then :bling:
mttraveller said:
how will it afect the sled. I am clueless as to the performance of my sled. .
That affects low end, from a standing start up until whatever speed your clutch starts shifting. It doesn't seem like that little bit would make much difference, but you will absolutely notice an improvement if you do remove a spacer.
