he probably meant the 2 bolts that hold the transfer rods to the rails.
alwaysthefinest said:I see your suspension has more grease nipples than mine too![]()
alwaysthefinest said:So what do the ice scratchers REALLY do? And second.... got the skid back in, all bolts tightened etc.... have the back end up off the ground, and when I give it gas, I hear the tack making clicking noises on the hyfax... I guess I never paid attention before, is that normal? I tightened the track tension the exact amount of turns that I used when I backed them off (10 turns to loosen them, ten to tighten....)
alwaysthefinest said:snip I tightened the track tension the exact amount of turns that I used when I backed them off (10 turns to loosen them, ten to tighten....)
