need suspension info!!
devinzz1
Newfoundland
Can somebody tell me what the max length shocks I can put on the front end of a 97 vmax sx? will viper shocks fit? what is the cleavis size I will need without the stock bracket?
Viper shocks will work, alot of people do that. You'll need to remove the old shock mount and install the top mount bushings that the Viper uses, they just press into the holes on the bulkhead. You'll see what I mean when you pull up a microfiche to order the bushings, or when you take off the old top shock mounts. Some people say they just use washers for that top bushing, but I would recommend the rubber bushing from Yamaha, they weren't that expensive, I think I paid about $7-8 a piece for them.
Thanks! I just got a pair off coles with the 440 springs already on them. but what did you guys pay for the viper/sxr top shock bushing? I nearly shit bricks when my local yamaha dealer told me it would cost me $17..... EACH!
Havent received shocks yet but they are stiffer so there will be less sag which means more ground clearance and more travel.
