with the new fuel(poor) standards you are going to want to open the fuel screws another 1/4 or so, do you have an issue with the idle wanting to rise? If so I would say that you are lean on the pilot circuit. Also have heard from the guys that race when you load the clutches the motor will want more fuel, so I am going to bet your fuel screw is the issue.
bogey
i will try that, the idle doesn't want to rise
mod-it
Are you absolutely positive the pilot jets are clean? You looked through them when done and there was a nice, round hole? Just spraying cleaner through them doesn't always get them clean...
bogey
ive had the carbs apart twice i know for the pilots are clean gauranteed the carbs are cleaned properly
How are your float heights? Carburetor screens? I had a bog off idle on my 99 sx 600 and turns out the safety switch in the throttle handle was bad and cutting the ignition for just a few milliseconds. I had the carburetors apart probably a dozen times, replaced fuel pump, lines, coils, checked the clutching, belt, CDI box etc.... I spent I bet close to $300 before I was messing around one day and unplugged the kill switch harness from the handlebars. Bog was gone. Plug it back in, bog returns. Just food for thought. Been there!
bogey
thanks i'll look at that too
mod-it
If flipping the choke helps, then it is a lean condition for one reason or another.
A couple of bucks
bogey said:ive had the carbs apart twice i know for the pilots are clean gauranteed the carbs are cleaned properly
Were the floats popped and top hats checked?
A couple of bucks
taylzee said:To me you have too much weight in the primary for engagement (4500rpm) which is pushing the belt up the primary and pulling the belt down the secondary too fast.
Kinda like starting out in third gear in your car/truck.
taylzee
A couple of bucks said:Kinda like starting out in third gear in your car/truck.
I was going to say that but then I read that he has been running it with this set up for a coouple years. If he likes the set up it's hard to argue.
A couple of bucks
If you have a new belt, throw it on and see if that changes anything. Sometimes an old glazed up belt doesn't help anything.
