A couple of bucks
Does the problem surface whether the sled is hot ,cold or it doesn't matter?
Problem manifested about a month ago, warm weather. Rather cold now, so doesn't matter.A couple of bucks said:Does the problem surface weather the sled is hot ,cold or it doesn't matter?
Sounds like the floats are down calling for more fuel ......... constantly. Even when engine is off. Just a WAG.badhabit1 said:Ok, update! Now I think I have some fuel issues, the previously full tank is almost half empty, think some of it may be in my crankcase. Plugs all wet when I pull them.
I've had carb apart a couple times, but I agree with you. Once rain stops I will remove the carb, again.... Thanks.A couple of bucks said:Sounds like the floats are down calling for more fuel ......... constantly. Even when engine is off. Just a WAG.
