mxmantater746
Hey guys I just had a new TPS installed and after sitting a week it doesn't even act like it wants to start... any ideas... thanks in advance....
bluewho
check for spark or if you removed carbs add alitle gas to cyl 2 see if it will fire,
mxmantater746
It does have spark... i'll try the gas thing...
bluewho
Around a table spoon or a 3rd of a oil cap off a litre jug works well.
mxmantater746
It doesn't even fire.. at all.... it ran perfect when I loaded it last weekend...
bluewho
Sideshow bob was helping bluemoster insall/setup his could check there posts for setup .
don't think you can blame the TPS for not starting.If you unplug the TPS..it should still start.Make sure you have spark..and if you do..putting gas in all 3 cylinders thru sparkplug hole should get her going..it should start to sputter/fire on you.Is something grounding out somewhere and the carbs ..are they really clean.Could of plugged jets solid with some old gas in the tank even.You have to try and eliminate 1 thing at a time..sorry there is no magic solution..
mxmantater746
3 new plugs big fat spark on all 3 gas dumped in plug holes pulled 20 times got nothing at all
spark plus gas = BOOM!!! don't know what to tell ya...check your compression numbers and see if that is good.....
Where's daman when we need him..he would usually be on top of this.....
Where's daman when we need him..he would usually be on top of this.....mxmantater746
thats what i thought but pull and pull and nothing like key was shut off
staggs65
like blue said gas + spark you have the recipe for ignition. if you have any compression at all it should fire up.
even if your kill switch was off..not saying it is...but maybe..lol you wouldn't be getting a spark then..so maybe check all wiring for loose connections..I am not an electrical demon..but something sure don't smell right in Yamaland....
is your key off..lmao..just kidding.Correct me if I am wrong Jeff..but if key or kill switch is off or wires to carb dissconnected..there wouldn't be any spark showing up.....so now it may boil down to a carb or even a fuel pump failure on you..but you shoulda had some smoke already......Murphey's Law I guess..This is where I would be grabbing a big hammer and swinging it a little..that's just me...lol
bluewho
It could be flooded......remove one plug and hold your finger over the hole when a buddy puls it over.
mxmantater746
I got it... lol... seems to be ok now... she's a testy b****h...
lolllllllllllllllllllllllmxmantater746 said:I got it... lol... seems to be ok now... she's a testy b****h...
I just bought a 2000 SRX 700 off a friend of mine. On a 15 degree average day, from a cold start, it would take anywhere from 25-40 pulls to even get it to pop once. We got to where on the first start of the day we would dump about 1/4 cup of fuel into the air box and after 2 pulls it would fire right up. My SX 600 was the same way but not as bad. Would take about 10-15 pulls. Same trick, same results lol
just get a can of quickstart..
mxmantater746
that's my only hatred toward that SRX...hard starting... other than that i wouldn't give it up for nothin'...
bluemonster1 said:just get a can of quickstart..
I don't like using that stuff but have resorted to before.
