Corey9965
Will a 99 SRX hood fit on a 01 SXR and will an SRX motor bolt in to same chassis
i am not exactly sure i belive the hood shape is the same the differance is the srx hood has a big bubble on one side cause the tripple pipes ...i think all belly pans are the same ....if so i would say the srx hood will go on sx body ....but the motor no cause the bulkheads are different were the engine mounts
hood nor belly pans will interchange between the models and look like its supposed to be there. the srx's are much wider.
engine can be adapted to fit, pipe fitment will be a challenge.
ottawaair
SRX hoods are much more roundes in the front. They will not interchange.
