track adjustment?
rodny51082
massachusetts
i just put in a new used track on my viper. i think the specs say somthing like 1"-1 1/4" at 20 pounds. but do i measure in the middle wher it is already sagging? it has about an 3/4" of sag as it sits with no weight. so should i just add a 20 pound weight in the middle and loosen it up till i get to 1 1/4"?
10kg (22lbs) / 25-30mm (.98 to 1.18 in)
Measured from the bottom of your hifax to the top of your track.
Take the distance measurement in line with your weight (point of largest distance)
