2002 vmax 700
what kind of riding are you doing? by gearing down I assume your wanting it to be quicker for a shorter distance?
I suggest using Turks tuning for your Sx 700, I followed exactly except for I kept the stock jetting. Runs exceptionally well, seems to be always in the proper rpm.
51/43 Helix, 8-ca weights w/4.5g rivet 1st hole and 3.1g in tip, 2-3 engagement shims, stock spring primary, silver secondary, 1 or 2 layers removed from head gasket and 20/40 gearing. Jetting: 140 mains
14.5 mm rollers in addition to above per trail or racing
hey Mrviper id like to know if i buy a sxr n i wanna put a sno stuff rumble do i need to change jettin
