fused or one part
Hey guys. This came off the chaincase side of my drive axle. Is this the bearing race fused to the collar or or is it suppose to be one part.
sockeyerun
Test Dummy
Here's a picture of what it looked like before it blew.
That's the speedo side isn't it pro side is just a 6205sockeyerun said:Here's a picture of what it looked like before it blew.
sockeyerun
Test Dummy
I'm confused? Are you talking about the chaincase side of the drive axle? That is just a bearing without the lock collar. Isn't the side of the old bearing your holding in your picture have allens in it?
No, i think that was just a collar of the shaft. Chaincase side.
sockeyerun
Test Dummy
Wow, If thats from your chaincase side, that spacer is a separate part. Was there anything else damaged in your chaincase, I've had a speedo side bearing side do that, I have personally never seen a chaincase bearing get that bad, ouch! So your saying that is collar #30 in the diagram below.
Yup I think it is part 30.I can't get them separated I even tried heat. so that is the bearing race fused to the collar?
9801srx
just look in side the peice you think is number 30 ,if it is it will have a o-ring groove cut on the inside. your lower chaincase seal rides on the outside of it.
sockeyerun
Test Dummy
If it's 30, Thats was alot of heat,wow. 9801srx has it right.
