Picked this up beginning of the week for $800. Sled sat with gas in it all summer long and gelled the carburetors up. Power valves had been serviced once since new and it now has close to 5k miles. I cleaned the carbs, cleaned and adjusted the power valves. I also replaced the gaskets and seals in the power valves and housings. It currently needs a speedometer cable, I'm going to replace all the driveline bearings as the one behind the secondary slid back. The seat covers rough on the hump, and it has the typical wire rub through by the steering shaft so the headlight flickers. It's a project but it runs sweet with the carbs clean and power valves serviced! It has triple pipes with stingers but I did acquire the stock can from the previous owner so I am probably going to install that as to not annoy the "DB Police."
http://www.youtube.com/watch?v=j6Rk7KeE-uM&list=UUHpEBIIjWlWknNTRparrdXA&index=1&feature=plcp
