Gitterdun1985
Need a good clutch setup for 1000 feet
sled has bender quads so should be running at 9000rpm correct me if im wrong.
YAMMIEGOD3:16
23/ 37 GEARING, YAMAHA W-W-W SPRING , NEED TO ADD WEIGHT TO THE STOCK WEIGHTS (8bu). 4.5. RIVETs INNER AND TIP. STOCK SPRING (silver) IN SECONDARY, INCREASE TWIST TO 90 3-6. i like to see ya around a 51/38 cam, 9000 is PEAK. quads add hp on this engine. benders were 14HP so you must add weight to primary. i have tested benders, psi and reichards on my 96 vmax 800. 3:16 (YAMMIE TONY)
Gitterdun1985
thanks Yammie Tony, so should my clutch enguagment be around 54-5500
I am not a V4 guy but that engagement seems quite a bit harsh, especially for a WWW spring
YAMMIEGOD3:16
4800- 5000. YOU CAN ADD A ENGAGEMENT SHIM OR TWO TO FINE TUNE. YOU DON,T NEED A HIGH ENGAGEMENT FOR SPEED RUNs. 3:16 (yammie tony)
