Is there a sticky or how to?
sofTAp
Newmarket
Hi guys,
I was searching, but couldn't find anything.
Do you guys know if there is a step by step how to clean the carbs off of a Phazer ???
I have 2 Phazer IIs and one Phazer 1 .... and they all need to be cleaned bad ......
Anyone have the steps for this???
Thanks a million in advance!!
Should be Mikuni butterfly carbs. They are very simple carbs. Get air passages, jets, needle valve, and starter jets clean. Check float height, and ensure carbs are synched. Be sure rubber plugs are in the right spots, and then reinstall and make all adjustments.
There is good info in the manuals, and on the web. Not sure why we don't have a write up on here. I guess I could do one next time I clean a set.
