I burned down mag piston on 02 viper in 2nd winter on a 40F day. I hope I got the newer coat piston.
skidooboy
so you know stang, all sunoco fuels have ethanol in them. i wont purchase it here is michigan for that reason. remember, higher octane isnt always the best choice. ski
91 octane with no ethanol is the best choice for a modded viper. Also if you have a 03 or newer model you may want to turn up your oil pump to the rich side of the setting. I lost a crank on a 03 Mtn Viper due to a lean oil pump setting last winter. I have now been turning up the oil pump on all 03 and newere Vipers that I put pipes on. I'd rather pay for extra oil than a new crank!
waldo
There all good now - just the pistons in the 02 sleds from the factory were non coated - if you go to buy one today - its an srx piston.
