Vmax540
Been using these http://snowcitymi.com/catalog/index.php?main_page=product_info&products_id=48 for close to 30 years without issues.
A couple of bucks
Vmax540 said:Been using these http://snowcitymi.com/catalog/index.php?main_page=product_info&products_id=48 for close to 30 years without issues.
That is like something I have been thinking about and was in my post #55 in the second paragraph. Didn't even know they existed in the powersports market.
All of the cooling air supplied to avionics in navel aircraft, is brought through something like this(descacant)to remove all moisture.
A couple of bucks
And please help the starving pygmies in New Guinea.A couple of bucks said:Dear Lord....I appoligize.
umm what if i can only get 90 octane up here in ak? it's like im in a foreign country or something.
A couple of bucks
If that is it, you'll have to use it. In conjunction w/ abit of octane boost. That discussion would be a whole nother can-o-worms though. You require 91 minimum in your SRX and if the fuel your getting is indeed 90 octane(which I doubt it is up there), you'll need something to make up the difference.
Can an airfield help ya out. A gallon of 100 octane in a fill up of that 90 octane should do the trick.
PhatboyC
A couple of bucks said:I don't know what the compression ratio was on my SX7 w/ one layer removed, but it ran very well on Shell 91. Not nearly as well with 93. And that particular station gets fresh fuel at least twice a week.
Isn't that normal for a 2 stroke engine. If you go higher then recommended you will get less power. That just the nature of 2 strokes. It goes without saying if you don't have a choice better higher octane then lower than 91 in the SRX.
blueblood68
I run the highest octane fuel i can find and add some gas line antifreeze to hel avod any water issues and to boot i also run egt gauges to make sure im not mellting down. I dont know why everyone doesnt run egt gauges.they are cheap compared too a rebuild.
blueblood68 said:I run the highest octane fuel i can find and add some gas line antifreeze to hel avod any water issues and to boot i also run egt gauges to make sure im not mellting down. I dont know why everyone doesnt run egt gauges.they are cheap compared too a rebuild.
What brand of EGT gauge do you use? Is it similar to this one? https://www.pegasusautoracing.com/productdetails.asp?RecID=64 Looks like a good idea to me !
A couple of bucks
For any I.C.E.PhatboyC said:Isn't that normal for a 2 stroke engine.
PhatboyC
Don't want to get in a 4 stroke debate here but this restriction doesn't apply to them.
Lets keep the discussion on 2 stroke.
SXViperGuy
Always throw unleaded premium In anysled for the first ride every season.
