triplexxx
- Sep 11, 2003
Just got done with cleaning the carb's on my V-max-500. I notice that there was a coolant line that went to the carb and I had to disconnect it. Is it necessary to bleed the coolant system since I disconnected that one line
sfury64
you might want to just run it a little and then check the lovel in the tank to be sure you didn't loose to much. Otherwise it should be ok.
