yammieguy
Guys got an 01 700 sxr new to me and have acquired a set of end dumps. I am looking for some feedback on the setup. First is the jetting, I am thinking of going 150 across the board, 52.5 pilots, raising needles one clip and adding one turn to the air screw. I have done alot of searching but wpuld love to hear what guys are currently running and the level of success from these setups!
yammieguy
Should I be gutting the airbox with the pipes??
srxman72
I am doing the same thing today with those pipes. I'm am going to try 147.5 mains, 50 pilots, raise needles 1/2 a clip. I found three jetting setups from turk and this is the one with the richest specs so I am starting with that. Ill probably turn out the fuel screws a 1/4 turn as well and fine tune from there. I wouldnt touch the airbox. Theres no snow here so I wont be able to run it though which sucks.
The_Paragon
Can you post a link to those set ups? I cant seem to even find em.
srxman72
I spent a lot of time looking for them so it wouldn't be easy to find the again, luckily I wrote them all down. They are as follows.
1st:
146.3 mains across
raise needles on mag and center 1/2 clip
possibly 47.5 pilots (he said some sleds need them some dont???)
2nd:
147.5 mains
50 pilots
raise all needles 1/2 clip
3rd:
147.5 mains
47.5 pilots
As for clutching 89L weights with 2.4g rivet with stock or ysy spring. And either 51/43 or 52/44 with green at 70 for secondary.
1st:
146.3 mains across
2nd:
147.5 mains
50 pilots
3rd:
147.5 mains
47.5 pilots
yammieguy
I have decided on the 52.5 pilots because someone here had reported idle hang with 50's also I am going with 150 mains because of today's fuel and I am in Canada. When were these setups posted? Alot has changed in fuel quality in the last few years
srxman72
Yes they were old post I found on this site through google. Did you get your pilots with a yamaha part number or through a mikuni catalog? I got my 50's today and there the correct shape it just that the bottom piece that has the holes in the side is huge in circumference and wont even screw in all the way.
yammieguy
Did not get them from yamaha but there were measurements in the book that match the ones in there
srxman72
The ones I have are Mikuni part # N224.103-50 and they don't work. Do you have the part number for the ones you have? My buddy at the dealer doesn't even know which ones to get.
edunn69
Are you looking for the stock Yamaha part # for the pilots?
srxman72
Nope I know that, I was looking for the Mikuni part number for the equivalent of yamaha's part number for a 50 pilot. I posted in the tech section and someone said it was Vm28/486-50. That's all i needed to know.
The_Paragon
I was kinda thinkin that Power in reccomended 145's accross the boars for mains? 147.5 and 150's would be way too rich!?
when you pipe a sled like that you will never get rid of the idle hang ,its because of the reassonance of the pipe! 50 pilots are plenty ,then you adjust the fuel screws ....the bigger the pilots, the less turns on the fuel screws! make sense?yammieguy said:I have decided on the 52.5 pilots because someone here had reported idle hang with 50's also I am going with 150 mains because of today's fuel and I am in Canada. When were these setups posted? Alot has changed in fuel quality in the last few years
extremelyfastmax4
the only reason u have hang up and it only happens when u run piped sleds compared to stock pipes these pipes make like 25 hp over stock so they need the fuel 50 piolt minumum 52.5 half better 55 is what i use on my red head it had 47.5 piolt and feel flat on its face when u punched the trotle wide open u allso should leave the air box stock and run holtzman temp compensator in the air box never have to jet again and no burn downs 143.5 jetting on these pipes is safe for -25 below zero . put a boost bottle on these red heads and do the peakperformance head and u have a 800 killer .
extremelyfastmax4
my set up allso gets 17 miles to the gallon
yammieguy
So you are leaving stock mains with a 25hp gain??
srxman72
How are you guys mounting the springs for these pipes. I couldn't get the MAG pipe to suck up into the grove on the CENTER pipe near the end of the pipes. It just hangs there and the only way I could get it to suck up to it was to put a flange spring on the circle holes on the corner brace of the MAG and CENTER pipes. I know that isn't right though. Here's how I have it now.
yammieguy
The bag I got my 52.5 pilots in says n100.606-75 but I cannot verify that is the original packaging, it is a mikuni sticker though
The_Paragon
SRXMAN72
Make sure the foward facing Stinger isnt rubbing on the bottom of the pipe for the center cylinder, or you'll have a hole in the pipe and a melted down piston. (pretty common)
Looks pretty close to me..
Another issue: the stingers never seem to want to sit down in the belly pan hole.. always wanting to come up and out of it.
