The_Paragon
Also,,, VHT paint doesn't hold up well at all... as you can see
extremelyfastmax4 said:the only reason u have hang up and it only happens when u run piped sleds compared to stock pipes these pipes make like 25 hp over stock so they need the fuel 50 piolt minumum 52.5 half better 55 is what i use on my red head it had 47.5 piolt and feel flat on its face when u punched the trotle wide open u allso should leave the air box stock and run holtzman temp compensator in the air box never have to jet again and no burn downs 143.5 jetting on these pipes is safe for -25 below zero . put a boost bottle on these red heads and do the peakperformance head and u have a 800 killer .
srxman72 said:Thanks for the heads up on the MAG stinger, it is definitely rubbing the pipe. And yes I have had better luck with the Rustoleum high heat paint, but it still needs a new coat every season to look good.
The_Paragon said:Where to put springs isnt such a problem with the Power inc trail can.
