Backwoods M Max
How loose can you get away with running a stock track before it will start to ratchet? MM700 with 141" yoki track, stock drivers. I never adjusted mine after I stripped the idler wheels off the skid last spring and it free hangs around 3/4 to 1". It didn't ratchet when I got the sled out for the winter but that was also just messing around in the yard not being hard on it. I have graphite hyfax strips for it before I go riding and was hoping for a good starting point when I tension the track back up. General concensus seems to be that the specified tension is too tight. I pick the back of my machine up with a tractor to adjust it so I have gravity on my side. I have a pull scale, can you be scientific about it and say run it at 15lbs for 1" deflection vs 22lbs for 1"?
Thanks guys, pray for snow!
