nystateboySRX
Is there anyway I can get better bite at the starting line? I have a stock track, 0.74 I think, with 144 studs at 1.15 Can I adjust anything to get better grip? Open to any suggestions......
Transfer Rods? Installed
nystateboySRX
and this makes a noticable difference? if so I might have to get some..
NY_SXR700
srxguy
...Transfer rods make a big difference...nystateboySRX said:and this makes a noticable difference? if so I might have to get some..
yamaholic22
lol, guessing that is with the 8CA's doug?
NY_SXR700
8DN-20's that day.
yamaholic22
lol, you must have a weight inventory better than the dealers
NY_SXR700
Actually, I raid Busters garage. Then I get a bill at the end of the season for stuff I don't return. I do have a ton of spare parts I should sell. Doug
GS438
- Dec 28, 2004
I would kill to have my SRX leave like thatNY_SXR700 said:Rods set to full transfer and it does this. Just don't ride it down the trail like this. You will end up busting the W arm if you do. Doug
NY_SXR700
Not with a stock skid. Our skids loose traction as they lift that is why a poorly tuned grass drag SXR/SRX jumps or hops down the track (hooks-up lifts and looses traction drops and hooks again.....). The SXR will squat a little, the SRX wants to lift the skis 3" and rock back to put the entire skid on the ground. A good setup on your SRX will look funny on solid flat garage floor. You will see the tail end is sticking up like your skid is bent. It's not it's just ready to rock into hook-up position. This wheelie thing easy to do with rods. I can stand that sled up and drag the rear bumper I almost flipped it over several times this day cuz the snow was so soft and sticky. Doug
nystateboySRX
how do you install them??
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
get a new camoplast track, I put a 9830H track in mine and I can take my dads rx1 off the line everytime and he has a ripsaw. Not even close, I swear by this track, killer acceleration.
98srx6
GS438 said:I would kill to have my SRX leave like that![]()
Put a new track on it and adjust it for full transfer as stated above and it will take off like that in the soft stuff.
