anyone have a jet and clutch set up for 8500+++
The temps were right around 30-35 deg for most of the time. It did get a bit colder at times and thats why i jetted up the needle to 2.5 for a little bit of safety. Mine was a bit rich when it was warmer but when it did get cold i was still in a safe spot for the famous mid range/ lean burn down.
Hope that helps
Thank you sarge and mod it. Sarge you clutch set up worked awesome I had to change the jeting a bit but everything was awesome.
Set up was
20-42 gearing
8dn weights
3.6gr in heel
.85gr in toe
41degree helix green spring 70 degrees twist
Jetting
152.5 mains
60 pilots
JN 3
FS 1.75
just for anyone who may need a setup in the future.
