Building Srx 440 mod motor need to know what heads are better 76 77 or ssr heads and were could I get them I have 1976 ported cylinders help
upland
Mod SRX
The 76 and 77 were both great race sleds, the 77 was the holy grail though. Stock specs show the 77 had more H.P. Call Leon at Koch's Performance and he will have loads of good info (and parts) on these motors. He is located in Crivitz WI.
Upland
The SSR was an awesome looking sled but didn't fare as well as Yamaha had hoped on the race track.
Upland
YAMMIEGOD3:16
8F2 HEADS AND 8H0 HEADS ARE VERY CLOSE. 8A7 HEADS I WOULD HAVE TO GO BACK AND CHECK TO BE SURE. THEY MAY BE CLOSE TOO. THE 8G9 OR 8J0 CAN BE MATCHED TO ANY OF THOSE AND ARE 100 TIMES EASIER TO FIND. 3:16 (yammie tony)
dynofun
- Nov 14, 2005
If you can find 76, 77 SRX or 8H0 heads that have been correctly modified I would use any of them as they are the same or very nearly the same. I would NOT modify a set that has never been cut however. They are just too rare and modded ones (especially since that is what you want) are all around. I would prefer a set that has had .020-.030" cut from the base and nothing else if it was me.
You can NOT modify 78-80 heads to be the same but you can make them work with the right people doing it. I may have some 76 heads I would be willing to part with but it will take me time to look if you are not in a hurry. I do have a set of race cut 77 heads I will sell if you are going to be putting this motor on a dyno.
Let me know what u got for sale and what u want for them and get back with me I'm not in any real big hurry it's a project in the making just rounding up some parts once again thanks for all the help guysdynofun said:If you can find 76, 77 SRX or 8H0 heads that have been correctly modified I would use any of them as they are the same or very nearly the same. I would NOT modify a set that has never been cut however. They are just too rare and modded ones (especially since that is what you want) are all around. I would prefer a set that has had .020-.030" cut from the base and nothing else if it was me.
Give me a heads up on those Srx heads I may b interested in both sets depends on pricedynofun said:If you can find 76, 77 SRX or 8H0 heads that have been correctly modified I would use any of them as they are the same or very nearly the same. I would NOT modify a set that has never been cut however. They are just too rare and modded ones (especially since that is what you want) are all around. I would prefer a set that has had .020-.030" cut from the base and nothing else if it was me.
Srx 440 power jet carbs
Need to no how to block off the power jets.and what jets is a good starting point.Motor is a 1980 block 1976 ported cylinders not sure what heads I'm still waiting on a reply from dynofun on wich heads he's got.
YAMMIEGOD3:16
what size carbs are these 3:16 (YAMMIE TONY)
They are stock 1979 Srx 440 carbs I believe 36 mmYAMMIEGOD3:16 said:what size carbs are these 3:16 (YAMMIE TONY)
YAMMIEGOD3:16
PRETTY SMALL FOR A MOD MOTOR. 3:16 (yammie tony)
