Let me know what u got for sale and what u want for them and get back with me I'm not in any real big hurry it's a project in the making just rounding up some parts once again thanks for all the help guysdynofun said:If you can find 76, 77 SRX or 8H0 heads that have been correctly modified I would use any of them as they are the same or very nearly the same. I would NOT modify a set that has never been cut however. They are just too rare and modded ones (especially since that is what you want) are all around. I would prefer a set that has had .020-.030" cut from the base and nothing else if it was me.
You can NOT modify 78-80 heads to be the same but you can make them work with the right people doing it. I may have some 76 heads I would be willing to part with but it will take me time to look if you are not in a hurry. I do have a set of race cut 77 heads I will sell if you are going to be putting this motor on a dyno.
Give me a heads up on those Srx heads I may b interested in both sets depends on pricedynofun said:If you can find 76, 77 SRX or 8H0 heads that have been correctly modified I would use any of them as they are the same or very nearly the same. I would NOT modify a set that has never been cut however. They are just too rare and modded ones (especially since that is what you want) are all around. I would prefer a set that has had .020-.030" cut from the base and nothing else if it was me.
They are stock 1979 Srx 440 carbs I believe 36 mmYAMMIEGOD3:16 said:what size carbs are these 3:16 (YAMMIE TONY)
