Power valves 98 SRX
Idle down,,,,, there will be an 1/8"rotation past that ,,,,,,but thats not how it runs under power..............
O.k. so thats why its traveling an 1/8 past the mark. So unpluging the single wire is not the preferred method?
staggs65 said:
how are you powering it up? all 3 of my sleds have the harness for adjusting on them (there when I bought them). not sure how they're wired as I never needed to check but maybe something with how they're wired: through the cdi or something?
I disconnected the servo harness plug and used the black/red and black/yellow wire. The tech page says power to blk/red and ground to blk/ylw but these way moved my servo clockwise instead of counter-clockwise..weird Had to reverse the connection?
Is this the factory test port harness on the 98 for servo motor.
I know on the viper I used the battery method and the connector is above the right footwell and it's a black connector. It had a black, red, and a stripped wire. I used the black and red and it went as advertised: counter clockwise. loosened the cables up (all in) prior.
i know if you turn the servo motor past the halfway point and hook the servo up to power via the test leads it will go the opposite direction intended. i found this out the hard way.. i was being a goof and playing with it and i turned it back too far and it took off the other way and sinched and bound up all my cables lol. :itchy: but either way. it trys to go it will always end up at the same spot ..power valve open.. in my experience playing with it
I ended up leaving the pulley off, re-started sled and idled it down so it did its own thing. Now the tricky part was getting the cable pulley back on in the right spot, aligning the holes. I had to manually twist the pulley counter-clockwise and hold it while putting the screw back in. After all said and done, my marks were lined up from last year. I just want to know why kirks way over travels it by an 1/8".
