Hard Starting SX700s
Cherrypicker
Michigan
We have 3 SX700s and a 98 SRX700, and they are all hard starting when cold. I have resorted to pouring some premix down the air box top opening to "prime" the carbs and sleds usually fire with 3 or 4 pulls. Some of the fuel will run out of the box, but it hasn't been an issue. Yesterday I went through this procedure and ended up setting the SRX on fire. To make matters worse it was on the 4 place trailer, with 3 SX700s still attached to my pickup. I was able to quench the fire with the second of 2 fire extinguishers, some windshield washer fluid and as much snow as I could gather.
I don't understand why this hard starting is happening, I have other small engines Honda and Briggs and Stratton that almost always start with less than 3 pulls, obviously it's a fuel primer issue, has anyone else incorporated a priming system in their sleds, much like some older Skidoo models used to have?
Never an issue when the sleds are warm, usually 1-2 pulls at most, even after they have set for an hour or two.
try doing the choke plunger mod.Remove the plungers and grind or file 1 mm off the tip..this will allow more gas for starting.Some swear by it.I have done this on my Srx also,but haven't tried starting it yet..waiting for snow...
i usually pump the throttle 3 times then full choke it when cold, started first pull yesterday. i cant imagine that the same thing is wrong with all four sleds.
Pumping the throttle isn't going to do a thing other then exercise your thumb! They don't have an accelerator pump.
Sounds like the chokes might be out of adjustment. Are the carbs clean? After these I would say do the plunger mod and you shouldn't have a problem.
I have never had to "prime" any of my sleds.
First off, honda,briggs etc are FOUR stroke with 1 carb hence the no mix gas. Horse of a totally different color! Carbs clean? Agree with choke being suspect. When pulling the choke flipper look at carbs and make sure they are full travel/fully choked. I adopted my buddies method a few years ago. Give they sled 2-3 preliminary pulls. Not pulling quite as hard. Gets everything moving and builds vacum in pulse line. Then give it a couple good pulls and fires right up! Even the 00 srx responds well after sitting a couple weeks.
What do you mean by cold. Sitting over night or 30 below zero. I have two 700 and usually start with 2 pulls in the morning unless it is below zero. Got tired of pulling ( 700s are no fun to pull when it is -30) and installed electric start on both. Make sure your carbs are clean ( and make sure you pull every thing apart when you clean). A little Seafoam in the fuel wont hurt either.
do you have a pic of the fire damage on the SRX.I would use Quick start before dumping pure gas down the airbox...
It hasn't been that cold, 5-13, but clearly it's a carb related issue, since I go through the carbs annually, don't think it's dirty carb, but I will tighten up the choke cable and see if maybe I'm running with too much slack. This is only an issue when sitting for a few days. I agree with difficulty pulling these things over.
Externally it looks fine, pop the hood and the airbox foam, top cage, are melted,
I have some belly pan damage as well. It is still sitting outside away from other combustibles in case I missed an ember somewhere. I will likely get it inside later in the week, and pull the motor, check the wiring, see if I want to take the time and expense to resurrect it.
Granted they are 4-strokes, the Honda and B&S, but don't understand what the difference in fuel whether mixed or not would make any difference. I would say they have superior or richer starting circuits. I may have the choke cable a bit loose, as I want some free play when I release the flipper, so I'll try that first, next do a search for the "choke mod?"
The carbs have been gone through, prior to riding season, (annual practice)
I usually do a slow pull at least once, as one of the sleds (milled) is a bit reluctant to spin. Thanks
I beleive you are right with the superior/richer starting circuit. By pouring gas in air box that efective what you are doing. My point is/was average B&S or Honda engine from from tank to muffler fuel travels how far? versus 2 stroke it runs down around crank and bearings and back up to be combusted. A closer comparisonwould have ben how hard to 4 stroke sleds start?
