This is my buddies sled. I just cleaned the carbs, cleaned and set powervalves as well. Both the temp light and the warning light blink 8 times in unison. I did a search but not much info on this...8 blinks is not listed on the service code document either. Some posts suggest it is the temp sensor?
gil7247
Mine is doing the same thing. Manual says temp sensor gonna try that cause it runs fine and blinks even when stone cold. Couldn't find and rub thru and cleaned contact still it blinks. I will post is the sensor takes care of it.
