wls
I have a 36 on my et340 oval racer, have a 340 main in it
jfpsteve
Nice clean looking sled and carb re-fit you have there. Good job!!
xfaexciter80
hey not only is the heat sheild important but you should make a sheild that deverts air coming out of your fan shroud away from you uni filter keepin the air going to your filter cool and constant i had to do it to mine when i went to filters and socks. you can attach the sheild to your clutch cover that way it gets sent out of the motor area hope that helps
THANX !jfpsteve said:Nice clean looking sled and carb re-fit you have there. Good job!!
On the clutch cover it is already an hot air divider,xfaexciter80 said:You should make a sheild that deverts air coming out of your fan shroud away from the UNI filter keepin the air going to your filter cool and constant.
I had to do it to mine when i went to filters and socks.
You can attach the sheild to your clutch cover that way it gets sent out of the motor area hope that helps.
but on the pictures it is not in place since the secondary clutch is off.
xfaexciter80
oh dah!!! haha sorry makes sense why i didnt see it haha
On road: 90 Km/h ---> 55 mphmarc8_2 said:Does it go faster ?
On hard packed trail: 80 Km/h ---> 50 mph
On loose trail: 73 Km/h ---> 45 mph
Track: 136x15x1"
Track pitch: 2,52"
Track drive: 7-Teeth
Gearing : 12 / 22
Anyone who can share some information regarding jetting a
Mikuni VM-32/34 carburetor on the ET-340 engine ??
jamie
I have concerns on the angle of your carb. Can you put an angle finder on the top and tell us what it is ?
What is your concern about the angle of the carburetor ?jamie said:I have concerns on the angle of your carb.
I have been running this setup for the last 3 seasons without any problems.
jamie
Just thought since your asking about jetting specs after 3 years of running it that way the problem might not be jet related and more an angularity problem that's all.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We run 38mm pilot 47.5 main 350 clutch is 52.5 gram spring is 120/310 stock secondary the clutch is a p85 polaris.
wls said:I have a VM-36 on my ET-340 oval racer,
Sorry guys, the VM-36/38 is a completly different carburetor then the one I using,2ooosrx said:We run VM-38 , pilot 47.5 , main 350 , clutch is 52.5 gram , spring is 120/310 , stock secondary the clutch is a P85 polaris.
so I have no use of your information.
THANX anyway !
I have no problem with the sled.jamie said:Just thought since your asking about jetting specs after 3 years of running it that way the problem might not be jet related and more an angularity problem that's all.
I'm just curious about what jetting people using with the same VM-32/34 carburetor on the ET-340 engine !
agripatrol
2ooosrx said:We run 38mm pilot 47.5 main 350 clutch is 52.5 gram spring is 120/310 stock secondary the clutch is a p85 polaris.
Are you running the stock air box with that?
Thanks,
G
