98 vmax 600 carbs full of oil
In the spring I will syphon as much gas as possible out of tank. Pull top of airbox apart, just far enough to hose the fogging oil to the carbs. Fire sled up, let it iddle most of the remaining gas out. When it starts spurrting out of gas I hog around 2 cans into air box so sled runs on fogging oil for a few minutes. It will smoke like hell. I pull the plugs and spray oil down into cyclinders. I only partially reassemble airbox (avoid the where the hell did that go or where the hell was this momments) Pulled the belt, let clucthes relax. Give the whole motor bay a nice coating of wd-40 or simslar to hold of corrosion. Put sled on stand and back tension of track. I was AMAZED with the carbs when I puled them apart this fall COMPLETELY SPOTLESS, EVEN THE PILOTS!
