No compression middle cylinder (#2)
gyrotee
Fremont Ohio
Was riding yesterday, and my sled started missing and popping. Pulled the plugs and determined the #2 cylinder had no compression whatsoever. Sled has over 7,000 miles. I've never messed with a 2stroke engine before... Where do I begin???
drain down the engine, bolt on pump cover that has a washer under it, I think between the pto and center cylinder.
pull head. This will give you the cliff notes on damage.
I have everything for that motor if you need something.
Did you have clean carbs and fresh gas in the tank? If not, that might have been the culprit.
hopefully the crank is still good, they like to ruin the center and mag cylinders when they go. I would enlist the help of someone who knows engines in your area to check it for you once you take it apart.
i see your in ohio, not sure where fremont is but i am over by the oh/pa line, will inspect for you for free if you bring it over.
