Good 1350 ft mph?
Handy Andy racing
Bobcaygeon , Ont
Hey guys ... I have a 99 srx 700 with a few mods was wondering what a respectable 1350 ft mph would be was gettin 104 mph last Sunday. Sled has 170 studs 24/35 gears 8bu-10s and a bunch of other goods
Yea ? Good to hear I was wondering if gearing was to high but seemed to be shift out decent. First run with those ramps... Sled is also ported...heads cut reeds n spacers bender can air box gutted cold air kit
i think you might pick up some mph with less gear in that distance if your using 9 tooth drivers. 23/38 is good for 110. 23/37=114 with clutches shifted fully 1:1. jmo
You planning to run that sled in Haliburton? We will be there with a couple sleds. I'm thinking your mph is a bit low. Betting trail stock 700 will be somewhere around 110mph. Your sled with the mods will run trail improved and it will have to be a bit faster.
That was my intent I was at gravenhurst last year but unfortunately the cv tech crank I put in last feb fell apart ...2 chunks of. Weld fell out where they welded the webs... Any ways I have everything but crank it just got picked up by courier today so I can't see it happening... Might go up anyway to check it out
I weigh like 130 lbs sled spins like crazy for first 200 ft think that could be why I'm only gettin 104 ? Last season with the 8dn weights and 120 studs I only got like 102 in 2000 ft ? Any ideas on makein it hook?
Andy if you make it to Haliburton come over and see me. We will likely only have 2 sleds. My truck blew a rear diff yesterday and I will only be able to pull my small trailer. Our 600 SRX may need a light weight driver if ur up for it!
Not 100% it was one I had lying around at work ... I was told it was a 52 degree straight? .... Haven't been able to identify it. Maybe someone on here can the numbers on it are 7MSRO that's it no marks names or nothin
sure it's a O and not a 8? 7msr8 is a max performance 52/40
