Handy Andy racing
Just went and double checked it definently a 0
staggs65
it's a max performance # just need to figure out what angle
staggs65
I found it listed as a 50/46 with a ? in the aftermarket helix thread in the tech faq section
Handy Andy racing
Oh nice ! Thanks ... How do I access that info? It's 0 for sure
staggs65
Handy Andy racing said:Oh nice ! Thanks ... How do I access that info? It's 0 for sure
go to the forum list, click on the tech faq forum, theres a thread there titled aftermarket helix list (or something like that)
Here you go: http://www.totallyamaha.net/forums/showthread.php?t=61494&highlight=aftermarket+helix+angles
The search function on this site is great, although for some reason older threads get deleted, something like only the first 200 results are shown?
jabber800
Andy the first time I went through this post I didn't notice your gearing. Why are you geared so high? You will never pull that gear ratio and are hurting your acceleration and day to day driving. We have run stock gear ratios in 2000 ft runs and have not run out of gear.
24/35 gearing is good for almost 125mph without any overdrive.
JMO but I believe your leaving alot of performance on the table.
Handy Andy racing
This sled kinda has a history ....at one point it ran 126 consistently that's why it has those gears I just never changed back
Handy Andy racing
Up at Haliburton now
averagesleder
Handy Andy racing said:Up at Haliburton now
How is the turn out? Good luck. I'm thinking about going to the Gravenhurst runs next month.
Handy Andy racing
Thanks for lettin my try the sled man it was a blast ! Do you know how fast it went on the second pass
jabber800
Andy thx for driving for us. Too bad we didn't have a stronger sled for you to pilot. Pretty disappointed with the 600! We did some testing after you left and determined that the engine will not rev up past 9600 rpms. I think the stator bad. We will replace it for tomorrow. Are you going to be around?
averagesleder
Andy, what speed did you reach? Jabber what speeds did you hit with your sleds?
Matt
Matt
jabber800
600 ran 111.6 Mph
Pretty disappointed with that #
Conditions where terrible but the sled was still weak. Hope we can solve our problems in the morning.
Handy Andy racing
Look s like the srx should make it to north bay with any luck. Just gotta try some gears and hope for best
jabber800
Good to hear! We may have a few more sleds with us in NorthBay. Where working hard on the Apex.
Handy Andy racing
I have a question .... If I were to put a single egt probe on my srx which pipe would run the hottest. ? Which pipe would I put it in and 10 inchs out from piston is what I was told ?
