badazzyammie
ok guys i got a 01 srx 1in predator track and a 192 studs and she just dont wanna bite. will transfer rods help me out? thanks for helping me out guys
YAMMIEGOD3:16
HOPE YOUR STUDS ARE 1.175. 3:16 (yammie tony)
badazzyammie
their 1.075 thats what bender racing told me to use
YAMMIEGOD3:16
BINGO. 3:16 (yammie tony)
badazzyammie
bingo in as i wasted my money on all those studs or bingo in thats what i ment
I use the same stud size on my 1 inch track also..they are good to go...SRX just has to much power...
badazzyammie
well should i buy transfer rods? is their any way to get that all the power to the ground? lol
let the front limiter straps out some
badazzyammie
thanks mr.viper how much though?
go about 1/4-3/8" at a time till you get the hook up and can live with the amount of wheelie its gonna do, you have to be able to turn sometime so you have to find a spot where you like it for the riding you do.
badazzyammie
ok thanks mostly trail riding lol. so like you said i need to steer haha. hey can i ask ya one more question?
badazzyammie said:ok thanks mostly trail riding lol. so like you said i need to steer haha. hey can i ask ya one more question?
sure at $6.50 a answer/reply no problem..........LOL!!
just kidding
badazzyammie
okay lol. why is my dads 02 srx beating my 01 srx i mean he blows me away from a rolling start
well, something is obviously differnt between the sleds, set up, condition of engine, clutchs,belt,track,bearings.
Hard to say thats a pretty vague question really. youd need to compare the 2 with about everything then find your gremlin in yours.
badazzyammie
well his is bone stock except a bender can no studs even. mine has a bender clutch kit and hauck growlers.
badazzyammie
oh my jack shaft bearing went out the next day but would it make me loose that bad?
badazzyammie said:oh my jack shaft bearing went out the next day but would it make me loose that bad?
that bad bearing ate up power , better check the rest of the bearings in driveline also and more then likely the clutch kit is worse then stock as well. repair the bearings and retry, if he still beats you , then you know its in the clutch kit!
motorhead327
Get rid of that growler. Put stock can in and waste him!!
YAMMIEGOD3:16
BINGO IN YOUR STUDS ARE A TAD SHORT. THATS YOUR PROBLEM. 3:16 (yammie tony)
that is the recommended size Tony..I have a good 1/4 inch past lugs and that should be good.
