YAMMIEGOD3:16
RECOMMEND SIZE IS ONE THING, GETTING ENOUGH PEN TRACTION IS ANOTHER MONSTER. ON A SRX WITH A 1 '' LUG, YOU ACTUALLY CAN GO TO A 1.2 BUT YOU NEED TO REMOVE PROTECTORS FOR FRONT COOLER. YOU BETTER THAN RUN YOUR TRACK TIGHT AND NO HARD BRAKING. SRX HAS TO MUCH POWER. 1.075 WAS CALLED OUT FOR .092 AND A 1.'' TRACK. VERY CLOSE ON THE 1 ''. THAT STD IS TO SHORT ON THAT TRACK. ESPECIALLY ON A SRX. srx will wag its tail all the way down the lake. 3:16 (yammie tony)
bufalobob
the correct stud length for the 1" predator for trail riding is 1.075". if the sled is still not hooking up then the easiest way to correct is w/ adjustable transfer rods. i have a 1" predator on my 835 w/ 192 1.075 megabites w/ 7* angled double backers & bender adjustable transfer rods. i have around 50 more h.p. than you & my sled comes out hard on normal trail condition surfaces. btw, the bender clutch kit works very well. what are your full shift rpms? if you have the orange primary spring it may need to be replaced. after time they can slack out. also, the hauck can does loose some h.p. on the dyno.
bob
bob
YAMMIEGOD3:16
Do What These Guys Recommend Here, You Already Have The 1.075. If That Still Don,t Cure It, Ya Need The 1.175. 3:16 (yammie Tony)
badazzyammie
it engages at aabout 4300 and will hit around 8400 the clutch kit has yellow primary and secondary and a 8mm shim on primary not sure on the helix.
bufalobob
earlier bender kits had a orange spring. later had a yellow/blue. your rpms are fine. put on adjustable transfer rods & go out & have fun.
bob
bob
badazzyammie
ok thanks for your help guys
torelloracing
Chisel tooth I had 192 and have too much traction its amazing ! Now I have 192 of some woodys signature studs and can't wait to go bad to the t-nut chisels !
