Biggest rear cooler
A couple of bucks
Ogle County Illinois USA
With the tunnel extension on from Hartman, there is plenty of room for a bigger rear cooler. Has anyone put anything else on an SX besides an SRX cooler. Didn't know if mabey a Viper,Warrior,Vector etc etc would fit?
If your tunnel extension is big enough I have a couple custom made U coolers I am willing to part with. Off the top of my head, the extension has to be for a 144" set up at a minimum.
tait89 said:
Do you think it would be possible to connect two rear heat exchangers together?
That wouldn't be anything too major. Cut the elbows off of one of them, add T fittings and a bit of work on the Hartman extension. I'd need to get another cooler though. So I might as well just get a larger one than the SX has from the git go.
Actually you'ld want to run them in 'series' I would think. Come out of one end of the coolers and run a line to the opposite end of the other cooler. Too much dinkin around for me.
Looks like a Hartman extension with a cooler added. I don't think the RX1's came with a cooler like that.
