I was setting the cables on my valves last night and couldn't find a battery to use my testing cable so I did the 900 rpm trick to get the servo setting at full open.I don't know why I never noticed this before but when I idled the rpms down the servo opened up and then it rolled back a little.The cables were loosened up so there was no pull of a cable to cause this.Does anyone elses SRX servo do this?I set the cables at this lower setting but I don't know why the servo rolled back that little weee bit after opening up initially.
i belive thats normal cause mine does that also ...it kinda rolles back 1/4 inch like it is centering itself ...
I kind of figured it must be I just can't imagine I never noticed it before.
