Canadian Viper
Canadian Viper said:would it be possible debris from meltodown went inside crankcase to center piston? It is only pitted
not supposed to run regular in those motor ...look like u maybe found the trouble ......detonation could create the burn down ...does the air box still untouchCanadian Viper said:Machine is at a friend garage, will take a pic Sun, and check that. starting to wonder if the ethanol 10% they added here took its toll. Burnt 3 tanks of premium so
far, but today burned regular. Most of last year I burnt regular as I have done all its life
mrviper700 said:Piss poor gas quality along with the mag cylinder that runs about 10-15 degrees hotter then other 2 cylinders = detonation,= burnt pistons... simple as that.
The reason the center one started it too, is also higher compression and the gas is too low of octane. The pto looks fine because its lower on compression, not making as much heat. The mid range cruising on the needle circuit is the bad spot on a viper, lots of ign timing puts extra heat in the piston, higher compression makes more heat,thats why I have been preaching to raise the needles on a bone stock sled.
You NEED to richen up the needles because the gas is very low quality these past couple years, your paying more(gas prices) for less quality......![]()
Canadian Viper said:Thanks mrviper700, will do, step 2, and will part with it! I will miss the sound of it. Never put a mark on it,burnt amsoil, and always treated me well. Will go the way of a 4 STROKE, Thanks againe everyone for the help,Great forum!!
