badman5555
i have a 04 vipers,when i let off gas coasting i`m getting a whining sound which seems to be coming from clutch side.is this normal or should i be looking for something?
mattlumley
did you change the jackshaft bearing behind the secondary and put the bolts in backwards. i did it made the same noise, check for scrapes on the backside of the secondary.
super1c
Super Moderator
Just chain case whine. Totally normal if not use to it. Freaked me out too first time.
tedgoesfast
my sx 700 and my rx1 always did this from new
WIsnoRyder
is it is the same whine your sled makes when you brake? If so loosen chain tension.
devinzz1
mine does.
badman5555
thanks,sounds like it`s normal,just bought a 97 vmax xtc it doesnt do it so i was just wondering.thanks again
badman5555 said:thanks,sounds like it`s normal,just bought a 97 vmax xtc it doesnt do it so i was just wondering.thanks again
thats because your vmax uses a differnt chain,non hyvo, the newer sleds from around 2000 use the hyvo chain and it does "whine".
badman5555
thanks viper...whats the difference in chains?
