'02 Viper Hauck/CPR pipes, no power
mod-it said:
Dawolf, you got lucky if the valves were stuck but they didn't pull through...
Yamaha Norway, I have SLP's and my uncle has Benders. I like the fit of his benders quite a bit better than my SLP's, plus Benders have the same peak hp rpm as stock, 8600 rpm. I think this is better for the timing.
thats the reason most the other manufacturers raised the rpms, to get away from the hot timing in the middle. I'll take the higher rpm triples on a Viper over the stock rpm any day. JMO
Huh, still learning things about this sled then...I always figured some performance was being left on the table by getting past the rpm that the timing was set up for.
