pulling comet clutch XTC 700
febigblockford
New Hampshire
Screw the pullers and just use the hydraulic method but you'll need access to air tools and a propane torch. Go to your local ace hardware store and pickup a 9/16x18 threaded bolt and a 7/8x14 threaded bolt(i know they claim it's 9/16 or 5/8 but mine was 7/8") and a with about 2.5" of threads. Turn the sled on it's side, remove the clutch retaining bolt. Wrap the bolt you picked up with teflon tape(go heavy on it, wrap it a good 5-6 times). Fill the center of the clutch with boiling hot water. Thread the bolt into the end of the clutch and then run it down with an impact wrench. It will remove the clutch faster than any puller I've ever used.
Just my $.02
Jeremy
sxr1000 said:
does it have a round aluminum cover or a triangle steel?
Round Aluminum 6 bolt. Nothing has added up right on this sled so who knows. My guess is it started as the 9/16", threads got destroyed so they drilled it out and tapped it with a 7/8x14.
Jeremy
