96' vmax 600 clutch
Yamasquaw
I searched abit and never saw the answer i was looking for. What other yammy cluches will fit this sled? Just asking for a buddy of mine.
Dajudge just had a thread looking for a secondary for a 95, per that thread 97 and up had a diferent spline on the jackshaft. Primarys are almost a one size fits all, just make sure the crank is same size/tapper. I have read guys using cat/poo/ski donts primarys on yamaha. I would narrow your search to 600 twins if you want to just put it on as set up should be close if not the same as what hes currently running.
I put a 2002 Viper primary on my 96 Vmax 600 and it bolted up and worked perfect with no changes! Max RPM is at 8000; engagement and mid-range are fine. I was told the triple clutches would work on a twin and they were right.
