Yamasquaw
- Jan 8, 2005
I searched abit and never saw the answer i was looking for. What other yammy cluches will fit this sled? Just asking for a buddy of mine.
I think they all will from 94 and up,you just have to calibrate correctly.
Devilin AblueDress!
Dajudge just had a thread looking for a secondary for a 95, per that thread 97 and up had a diferent spline on the jackshaft. Primarys are almost a one size fits all, just make sure the crank is same size/tapper. I have read guys using cat/poo/ski donts primarys on yamaha. I would narrow your search to 600 twins if you want to just put it on as set up should be close if not the same as what hes currently running.
Excitabletom
I put a 2002 Viper primary on my 96 Vmax 600 and it bolted up and worked perfect with no changes! Max RPM is at 8000; engagement and mid-range are fine. I was told the triple clutches would work on a twin and they were right.
