davidgboy
please take part in the following poll. first select the option which best describes how u will be storing sled(s):
1) outside prone to rodents and changes in temp. and humidity
2) outside not prone to rodents but prone to changes in temp. and humidity
3) inside not easily prone to rodents and in a fairly stable enviroment
4) inside not easily prone to rodents but prone to changes in temp. and humidity.
now choose the actions or inactions that apply:
a) will not be running engine until next riding season
b) will be running engine periodically
c) engine fogged
d) engine not fogged
e) fuel tank emptied
f) fuel tank full
g) fuel tank partly filled
h) treated gas left in fuel pump
i) treated gas left in carbs.
j) carbs. drained
k) air box removed
l) clutches removed
m) exhaust pipe and muffler removed
n) will be blocking off exhaust
o) will be blocking off carbs.
p) will be running from seperate container with fresh gas each time
q) will be opening cowling often to check for rodents.
r) will be setting traps for rodents
s) will be taking other precautions for rodents
t) u have pet(s) that help with rodent control
please list other actions or inactions not listed here
my selections: 3-b-d-e-h-i-p-t
please include this thread with your response for everyones convenience
thank you for your participation.
c) engine fogged
f) fuel tank full
j) carbs. drained
k) air box removed
l) clutches removed
huh????? a little to much for me ...lol
motorhead327
3/4 C/e/h/i With Atf In Carbs And Fuel Pump, Belt Removed, And Weight Off Suspension. Everything Sprayed With Silicon Spray.
davidgboy
bluemonster1 said:huh????? a little to much for me ...lol
oh come on monsterman pretend you are in school again!
staggs65
I store mine under water. constant humidity
davidgboy
staggs65 said:I store mine under water. constant humidity
you are no fun!
SRX500kid
WTF!!!!!!!!!! i just sore mine on the trailer and start them every other week!
staggs65
i had fundavidgboy said:you are no fun!
davidgboy
hey i quit drinking any alcohol about a month ago, must still be experiencing withdrawl symptons. please be patient!
davidgboy
what was my excuse before? once again please be patient, i will think of something.
davidgboy
SRX500kid said:WTF!!!!!!!!!! i just sore mine on the trailer and start them every other week!
no need to freak out. just calmly list your selections. it seems your selection would be something like this: 2-b-d-g-h-i-q. excellent child!
come on people it is called a sense of humor. alright so i may be exaggerating a bit.
AC DC had a good song..Have a drink on me!!!
davidgboy
bluemonster1 said:AC DC had a good song..Have a drink on me!!!
lol!!!! i will think about it! where are your selections? come on man just get a pencil and piece of paper and write them down and type them out. please! lets see which micro-brew should i choose?!
....weres the sell sled and buy new one next year box????
...just sold mine today sad to see her go almost brought a tear to my eye ...but i know she will be loved by the next guy
Rich..you don't need a sled if there is no snow......save your $$$$
4 Acegu.
Can you give an example of #2?
The weather will constantly change OUTSIDE?
Rustman
3 a, c, g, l. No ethanol to worry about, inside and climate controlled, no rodents!
Excitabletom
World ends December 21; no need to do anything. Ride them year round this year!
throw all common sense out the window..now is the time to ride..hit the gravel,hit the water..what you have to lose.At least on Dec 21 you can say you rode your sled..snow or not...as the World turns upside down and drowns us..lol
Devilin AblueDress!
Just for the sake of arguement I will be doing several storage methods and let every one know the results. I never even started 00 srx7 this year. stored last year with fogging oil alone. Cleaned carbs and put cluches back on so I will be giving each carb a snort of fresh oil and taking clutches back off. Stored both 99srx7's with atf and a snort of fogging oil in plug hole. 98 srx600 and 00 sxr7 will get just fogging oil and clutches will be removed as well. All sleds will be stores with empty tanks. I have an electric in line pump to empty 99%, leave cap off for the lil bit left to evaporate and then before re-filling I shop vac the tank, I have a pvc tube made just for this. All the 700s stored in a enclosed 4 place trailor and srx 600 in a clam shell 2 place. the 4 place wont have the severe swing in weather as the 2 place will. As stated in other posts rodents are irrelevant. Unfortunately no matter what method is used IF YOUR NOT DOING IT RIGHT THEN YOUR WASTING YOUR TIME. Some guys say pulling clutches is unnessary but at the least you need to pull the belt off the sled. As far as starting it every couple weeks all summer.......probably better off to use staggs (underwater) method!
