02 Viper Speedo cluster blinking
Nathan Chase
Beechwood NB
Last week started sled up and the speedo, tach and gas gauge started blinking on and off, as the tach needle will go thru a sweep and red ! light comes on for a second just like when the sled used to start. Something else that started at the same time the battery seemed to be completley flat after working just great a week before. Checked cables to battery and all seemed fine and wires from belly pan to the guage cluster have no breaks in them that I can find. As far as I can tell the head lights have no issues, working just fine. Do you have any other areas I can check? starting to really scratch my head on this one. Thanks
you have a loose connection somewhere. If thats a viper er the tach and everything with not work right unless the battery is hooked up. Its either a bad battery or loose conection somewhere. Check the ground on the engine block. My dad's vmax ground wire broke off this year. Its just a thought. Good luck!!
