i was thinking about it last nite, what to use to clean my primary clutch, water& soap,,parts cleaner& air,, brake cleaner&air, preasure washer , just to list a few , looking for a good idea thanks
here in the shop i pull them off and remove the weights and rollers .....depending on how dirty they are they will get split all the way down i use the parts washer and a stiff brush and scrup then a spray if off with brake cleaner and air to dry then a little scotch bright on the sheaves and then wipe them down with acetone
