I have a little mystery on my hands. First off this is a 2000 mountain max. I have purchased a peak performance head and am installing it now. So I unfortunately did not check what the squish was before I pulled the head off, but it was running with no problems. Here is part A. of the question. The previous owner has 5, yes 5 layers of gasket. I find this odd. does anyone know why you would put 5 layers. I seperated and counted them. Stock is 3 I have heard of removing the middle one for increased compression, but adding 2? I want to understand what was trying to be accomplished by adding 2 layers. Before you answer read on.... So I installed the head, according to instructions, with a brand new set of EOM gaskets whole (3 layers). I tighten them down. I check squish. I am not a mechanic, but read alot. I use the solder method as descibed. the outside cylinders are good .061 on each. The middle concerns me, I checked it at the wrist pin twice. .049. Now this is tight. The MM head is one piece. So I either jack up the whole thing. Or leave it. If I want to try and lift the whole head up one layer I could do that. The split apart gasket I have is saying it is .026 thick. So adding it would mean .075 in the center, but .087 on the outside cylinders. From what I understand .055 is where I want to be. I am thinking about taking the head off and installing 1 layer. Then re-install and check squish, but how bad is .049 on the center cyl? I want the increased performance, but I do not want a re-build on my hands. Help Please, and thanks for any response.
