Turbo banshee build
coryv4
Michigan
just thought you guys my be interest in something ive been building.
heres some specs.
421 cub
alcohol
n down 1-5 override tranny.
105lbs of comp
garrett m24 a/r80 turbo
15lbs of boost
kit is known to make 70-90hp depending on pipes and carb size with out turbo
some builders are estimating i am in the 150+hp range.
the next thing i am going to be investing in is a 30 shot, extend the front of frame 14 inches, and billet tranny.
staggs65 said:
sounds like fun. what are you going to do with it, sand drags or ?
hill shooter/ sand dragger. im making a detachable wheelie bar for it because hill shooting a wheelie bar would be bad on the whoops and when i have it geared for 300 foot it stands straight up even with that +12 swing arm.
A couple of bucks said:
Is the Banshee a....350cc, two stroker? That thing looks like it is ALL GO. Something out of MAD MAX.
yeh banshee 350 with a 421 bigbore stroker. its all go shee doesnt like to play lol. on asphalt i can lay down a burn out from 2nd gear to 5th no brake just power even if im rolling and put it to the bar.
i am also thinking about shortening the stinger tube to bring the turbo closer to the motor it would prolly help alot with heat and spooling.
no there really isnt much lag if any. i would sa about 5lbs when i drop the clutch then after about 20 feet im at 15lbs.
we are going to have to hold off on that i just broke a set of reeds they should be here soon.
